Repetier-Host setting on ABS print
Posted: Wed Apr 01, 2015 3:33 pm
by animetown9
I was wondering any have a good setting for Acrylic Geeetech I3 pro B 3D Printer
Repetier-Host, windows 7
Filament 1.75 , nozzle 0.5mm
ABS filament.
thank
Re: Repetier-Host setting on ABS print
Posted: Wed Apr 01, 2015 4:26 pm
by zhangxueyou
Actually, you just need to modify the nozzle diameter and layer height.
slicer settings(1.75-0.5).zip
(569.25 KiB) Downloaded 1975 times
Posted: Wed Apr 01, 2015 5:30 pm
by leonardo.galardi@gmail.com
I see Extrusion multiplier = 0.6 in Filament Settings, ABS 1.75 mm. Why ? I think it should be 1, right ?
Posted: Wed Apr 01, 2015 5:42 pm
by zhangxueyou
It's hard to say. You can try 0.6 and 1 respectively.
Posted: Tue Dec 29, 2015 4:23 pm
by axenias
Hello friends, do you know if these settings are good for nozzle 0.4 too???
Posted: Tue Dec 29, 2015 8:52 pm
by Mark
I think it will be ok, but I think layer height is too big, I can give you my settings for ABS, using repetier1.6.0 and 1.75-0.4 ,single I3X printer.
config ABS.rar
(1.29 KiB) Downloaded 1717 times
Posted: Tue Dec 29, 2015 10:40 pm
by axenias
Ok, well, thank you! I have an i3 pro b printer. I will give a try to your config.
Posted: Thu Jan 07, 2016 1:48 am
by axenias
Hello again, i was wondering if there is some ready config for the same bodel but for cura, not repetier! Is anyone know if i3 pro b can play with cura 15.04.3??
Thank you!
Posted: Fri Jan 08, 2016 4:59 pm
by Mark
I could run the printer with the built-in cura engine in repatier host 1.6.0, so I guess it will be fine.
