CONNECTING AND HEAT BED
hI THIS IS A NEW PRINTER OUT OF THE BOX, I HAVE DOWN LOADED THE SOFTWARE FROM THE WEB SITE REPETIER HOST. AND EVEN THE EXTRUDER IS NOT HEATING UP. CAN YOU HELP ME WITH THIS PROBLEM THANKS
zhangxueyou
Re: CONNECTING AND HEAT BED
Is the extruder connected correctly? What is mainboard type?
THE MAIN BOARD IS SANQUINOLOLU REV. 1.3A
EXTRUDER IS CONNECTED RIGHT AS FAR AS I CAN SEE
zhangxueyou
Did you change something of firmware? Where is your firmware from?
THE FIRMWARE FROM THE REPITIER HOST WHICH WAS DOWNLOADED
NOTHING WAS CHANGED, THE FIRMWARE IS REPETIER HOST
zhangxueyou
RepetierHost is not firmware, it is a software used to print model online, control the printer, and save stl files as g-code file to print offline.
I KEEP TELLING YOU THE PRINTER HAS NO POWER, NEED NEW POWER SUPPLY AND MAT BE NEW BOARD
HELLO!
I KEEP TELLING YOU THAT THE PRINTER IS DOA. THERE IS NO POWER COMING OUT OF THE PRINTER, NO LIGHTS NOTHING
