Z and X axis end stops
nilsson
Post by nilsson »
Have a strange troubles with my Z and X axis end stop, the only one that works properly is the y axis . have tried to change cables tested a completely new ramps cards with the exact same firmware without great results. the firmware have I received of geeetech so yeah assumes that it will be ok.
also even compared it against standard marlin.
The problem in itself results in that I can not calibrate the axis against the heat bed because I do not get a zero value on the axis .
I receive a zero value on the y axis
so it works of course as it should
zhangxueyou
Re: Z and X axis end stops
Post by zhangxueyou »
Sorry for replying so late because there are so many new posts.
Can you take a picture of your wiring?
nilsson
Post by nilsson »
The problem is solved now and the printer makes pretty good prints
