ME CREATER NO POWER
bandit
ME CREATER NO POWER
Post by bandit »
HELLO! WENT TO POWER UP THE PRINTER, THE POWER SWITCH LIGHTS AND IF I PLUG IN USB DISPLAY COMES ON WITH NO INFORMATION, AND ON MAIN BOARD RED LED LITE IS ON. LED 1 ON POWER SUPPLY IS DOES NOT LITE UP. THE FUSE IS GOOD, CHECKED WITH OHM METER. I AM GETTING DISGUSTED WITH THIS PRINTER, ISSUE AFTER ISSUE. DUE YOU HAVE ANY THAT CAN WORK ON THIS PRINTER LOCALLY IN THE FORT LAUDERDALE AREA, USA. I NEED HELPPPPPPPP. I HAVE NOT BEEN ABLE TO MAKE ONE PRINT. EXTRUDER DOES NOT HEAT UP. DID I GET A LEMON. PLEASE HELP.
HOPE TO HEAR FROM YOU ASAP( AS SOON AS POSSIBLE. MY BUSINESS IS DEPENDENT ON THIS MACHINE.
THANKS :cry: :x :x :evil:
zhangxueyou
Re: ME CREATER NO POWER
Post by zhangxueyou »
1. Please turn on the printer, check if you computer detects the printer.
2. Please check if input voltage equals the AC voltage of your country.
bandit
Post by bandit »
HELLO, THE SWITCH IS ON 110V, THERE IS NO POWER IN THE PRINTER SO HOW WOULD THE COMPUTER RECOGNIZE THE PRINTER. BARE IN MIND THAT I HAVE A ELECTRONIC BACK GROUND, I AM A RETIRED ELECTRONIC TEACHER OF TRADE SCHOOL..
THE RIGHT THING TO DO WOULD BE TO SEND REPLACEMENT POWER SUPPLY. THERE IS A SLIGHT CHANCE THAT THE SANGUINOLOLU BOARD MY HAVE BEEN DAMAGE ALSO. PLEASE DO NOT MAKE ME WAITE FOR THESE ITEMS.
THNKS
STEVE
zhangxueyou
When you connect the printer and computer via USB cable, Check if there is a new COM port at "computer>manage>device manager".
bandit
Post by bandit »
THERE IS NONE. THANK YOU
bandit
Post by bandit »
I JUST TOLD YOU THERE IS NONE. THERE IS NO POWER IN THE PRINTER
zhangxueyou
Please do not feedback similar problems in different threads. I can't provide you with better service.
