Auto-home is going in reverse
pixelatex
Post by pixelatex »
I have the prusa I3 mendel printer form geeetech. But when I select.. 'auto-home' on the LCD it goes in the opposite direction of where the stoppers are mounted..
I'm sure the stoppers are in the correct spot so I don't understand what's wrong..
I wanted to check the firmware of the sanguinololu board but I can't seem to access that.
zhangxueyou
Re: Auto-home is going in reverse
Post by zhangxueyou »
Try to move the motors through LCD(prepare>move axis>move 1mm>move X/Y/Z), check if they move in the opposite direction.
pixelatex
Post by pixelatex »
If I move to axis from 0 to 100:
The X will move right to left, the Y will move from front to back and the Z axis will from up to down.
zhangxueyou
Reverse the connection of z motors on mainboard.
pixelatex
Post by pixelatex »
How? It's not like I can plug them in backwards? The connector only fits in 1 direction
zhangxueyou
Of course you can.
pixelatex
Post by pixelatex »
You are talking about the connector on the sanguinololu board? The connector has a plasic bit underneath it that only allows you the plug it in one direction
zhangxueyou
Oh, sorry, I forgot.
So you have to change its direction in firmware. Do you have firmware?
pixelatex
Post by pixelatex »
I've been looking for the firmware but I can't find it anywhere.
zhangxueyou
Please leave your email address, I will send you the firmware.
