Prusa i3 acrylic extruder ticking
k3tzor
Post by k3tzor »
Hi there
So I'm trying to get my printer to work. BUT it's still not working and the problem is that the extruder motor ticks when trying to get filament out.
I've already tried:
  • Twisting the current on the stepper motor
  • Checking the stepper motor/jumpers
  • Cleaned the whole extruder pipe and given a new nozzle
  • Tried the tension screw
  • Calibrated the extruder
Still nothing helps.... I'm getting sick of this, how the heck is this going to work???
zhangxueyou
Re: Prusa i3 acrylic extruder ticking
Post by zhangxueyou »
Please tell me what your mainboard type is, how do you connect the extruder motor?
k3tzor
Post by k3tzor »
I've got the ramps 1.4 and just the cable connected to E0 with the 3 jumpers onder the stepper motor
zhangxueyou
What is the distance between the nozzle and hotbed?
k3tzor
Post by k3tzor »
I levelled the bed with a paper that can fit between. Also removed the springs because of the always levelling the bed again was annoying so fixed the bed in place
zhangxueyou
After you move Z axis upwards, is the extruder motor working while the temerature is more than 175 degrees?
k3tzor
Post by k3tzor »
It always starts ticking, when I push it trough manually it will work for 50mm and if it stops and try again, it will tick again, tries the temp till 210 fo pla to be sure
k3tzor
Post by k3tzor »
zhangxueyou wrote:After you move Z axis upwards, is the extruder motor working while the temerature is more than 175 degrees?
Here's a movie about it again:
https://www.youtube.com/watch?v=yHb-XBTSghk
zhangxueyou
Please swap the extruder motor driver with x, or y or z motor driver, check if still happens the same thing.
k3tzor
Post by k3tzor »
I will try it when I get home, heres a better movie about it: https://youtu.be/GjSS-VQ877w
