This log file appears.
____________________________________________________________________
16:28:48.720 : echo:Acceleration: S=acceleration, T=retract acceleration
16:28:48.748 : echo: M204 S3000.00 T3000.00
16:28:48.941 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
16:28:48.994 : echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
16:28:49.019 : echo:Home offset (mm):
16:28:49.047 : echo: M206 X0.00 Y0.00 Z0.00
16:28:49.068 : echo:PID settings:
16:28:49.105 : echo: M301 P22.20 I1.08 D114.00
16:28:49.371 : Error:0
16:28:49.420 : : Extruder switched off. MAXTEMP triggered !
16:28:49.458 : N4 M105 *3
16:28:49.500 : N5 M111 S6 *66
16:28:49.526 : N6 M80 *61
16:28:49.547 : Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
_____________________________________________________________________
And the Hotend and heat bed turn on with on being ordered and the stepper stop complete movement.
I need help!!
Thank You in advance.
