Software/Firmware installation
Jorzuiz
Post by Jorzuiz »
Hi, i've been reading posts from this forum in order to install all the firmware that i need for my printer to run, but i have some problems.
My model is Acrilyc Prusa i3 with Ramps 1.4 and Arduino Mega 2560. What drivers do i need to install in Windows 7? What firmware do i have to burn? How do i burn it? How do i make the connection later with the RepetierHost?
As i said i've been reading some posts and cant understand it well because im not used to that complex tasks.
Thanks for the help.
zhangxueyou
Re: Software/Firmware installation
Post by zhangxueyou »
1. The driver you need to install is Arduino Mega 2560.
2. The firmware you have to burn is for ramps1.4.
3. As for how to burn the firmware, you can refer to:
http://www.geeetech.com/forum/viewtopic ... 14&t=16097
Sincerely hope this link will satisfy you.
4. How to connect the printer with Repetier:
1) Connect your printer to PC via USB cable.
2) Open Repetier, click "Printer setting" near top-right corner of Repetier, choose correct COM port(You can see it under Device management) and buad rate(250000).
3) Click "Connect" near top-left corner of Repetier.
Hope my answer will satisfy you.
Jorzuiz
Post by Jorzuiz »
When i drag all the files from the i3 firmware to the arduino executable it opens and repeat me dozens of times the error: "Processing can only open its own sketches and other files ending in .pde"
What should i do?
Jorzuiz
Post by Jorzuiz »
I have further tried with an updated version of arduino and it stops giving me taht error, but it shows this whe i try to verify the code:
Arduino:1.6.0 (Windows 7), Placa:"Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
sketch_apr15a.cpp.o: In function `loop':
/Arduino/sketch_apr15a.ino:1: multiple definition of `setup'
Marlin_main.cpp.o:C:\Users\Jorge\AppData\Local\Temp\build7954601488781043788.tmp/Marlin_main.cpp:433: first defined here
/Arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.8.1/../../../../avr/bin/ld: Disabling relaxation: it will not work with multiple definitions
/Arduino/sketch_apr15a.ino:6: multiple definition of `loop'
Marlin_main.cpp.o:C:\Users\Jorge\AppData\Local\Temp\build7954601488781043788.tmp/Marlin_main.cpp:491: first defined here
collect2: error: ld returned 1 exit status
Error de compilación
activala desde Archivo > Preferencias
Jorzuiz
Post by Jorzuiz »
I've tried to upload the code and gives me this error:
avrdude: ser_open(): can't open device "\\.\COM3": Access denied.
avrdude: ser_drain(): read error: Controlador no válido.
zhangxueyou
Please try to upload with Arduino 1.0.1:
http://arduino.googlecode.com/files/ard ... indows.zip
Choose correct Serial port before uploading.
