Page 1 of 2
Mightyboard Rev E wrong power connector
Posted: Tue May 05, 2015 11:05 am
by fruity
Hi, I have the original power supply for the Makerbot. It has a four pin connector. My Mightyboard has only two slots. On the underside there is what looks like a transistor or a diode.
If I replace the two pin female connector with a four pin female connector, will it break because of the diode? Or is it ok so I don't have to cut my beautiful male 4 pin connector.
Thank you.
Re: Mightyboard Rev E wrong power connector
Posted: Tue May 05, 2015 11:19 am
by zhangxueyou
It's ok. But please mind "+" must be connnected to "+" , and "-" to "-".
Don't care about transistor.
Posted: Sat May 09, 2015 12:38 pm
by fruity
I just plugged my new Jameco power supply into the Mightyboard and immediately got smoking capacitors. I think I plugged everything in correctly, as the two +24V wires were going into the + side and the two - wires were going to the - side.
Posted: Sat May 09, 2015 1:47 pm
by zhangxueyou
What is the output voltage of power supply? You plugged 4 wires to Mightyboard from Power supply?
Posted: Sun May 10, 2015 3:50 am
by fruity
The Mightyboard is receiving 24V from a new Makerbot Replicator 1 official power supply. I just checked it with the voltmeter again. the two positive legs are getting +24 over the two ground legs.
Posted: Mon May 11, 2015 11:10 am
by zhangxueyou
Which capacitor is smoking?
Posted: Sat Aug 22, 2015 9:23 am
by fruity
I just read the schematic for the Geeetech Mightyboard Rev E.
Are the correct inputs 12 V, not 24? I have TWO fried boards!!
I want a refund or I want to know what capacitors I can fix.
Posted: Sat Aug 22, 2015 9:24 am
by fruity
More than one was smoking. I tried plugging it in again after you said that to check, but I couldn't tell.
Posted: Sat Aug 22, 2015 4:24 pm
by Mark
Can you post a pic here? And the way you connect it, I want to know which capacitor is smoking, tks!
Posted: Wed Sep 02, 2015 6:06 am
by fruity
Mark wrote:Can you post a pic here? And the way you connect it, I want to know which capacitor is smoking, tks!
Here's the picture. Can you help?
