Y Axis Problem
3DPO
Y Axis Problem
Post by 3DPO »
all items are stretched on the Y axis. Please see video where I try to print a cube.
zhangxueyou
Re: Y Axis Problem
Post by zhangxueyou »
There are 2 reasons may cause this problem:
1. All the axes are not auto home before printing, so the printer can not recognize the correct position. You should let all the axes auto home before printing.
2. The model you are printing is too big on y axis, please confirm the size of cube is less than 200*200*180mm.
3DPO
Re: Y Axis Problem
Post by 3DPO »
I always do auto home before printing. I still have this problem. What can it be?
zhangxueyou
Re: Y Axis Problem
Is the printed model is longer than it should be on y direction?
3DPO
Re: Y Axis Problem
Post by 3DPO »
the cube is 4x4 cm but prints out approximately 4x20cm. the model is stretched on the Y-axis. I have the same problem when trying to print other models.
zhangxueyou
Re: Y Axis Problem
1. 3 jumper caps are not plugged under y motor driver.
2. Print size on y direction is amplified for 5 times in Repetier.
Please check.
3DPO
Re: Y Axis Problem
Post by 3DPO »
can you show me a photo of how the jumper caps should be? I cant find anything in the instructions.
zhangxueyou
Re: Y Axis Problem
3DPO
Re: Y Axis Problem
Post by 3DPO »
please see the attached photos. Do you see the problem? I removed the chip to show you underneath it.
zhangxueyou
Re: Y Axis Problem
Sorry, but I can't see anything attached.
