GT2560 File Burning
Hurdart
GT2560 File Burning
Post by Hurdart »
Putting the pieces together, running a few tests. On the GT2560 board wiki page, File Burn section 3.3, following port connection, It says..."Load in the file you need to burn, Click the “check ()” button to check if it is right and then click the “->” button to upload" What is the file i need to burn? It is a little ambiguous. Can someone point me in the right direction? -Much Thanks :D
Link to page:
http://www.geeetech.com/wiki/index.php/ ... le_Burning
zhangxueyou
Re: GT2560 File Burning
Post by zhangxueyou »
That is the process of burning firmware. You don't have to do that, if you bought a whole printer with GT2560.
Hurdart
Post by Hurdart »
Hi Thanks for the response. I understand the process, what file is it referring to? I bought the board separately, not as a kit.
