From home to 200, but X axis only moved 100
XYZM
Post by XYZM »
What do I need to adjust???
My X Y Z and limited to 200 200 180
Repetier thinks I am at 200 ,200 180, when I really am at half way those points
zhangxueyou
Re: From home to 200, but X axis only moved 100
Post by zhangxueyou »
In file "configuration.h" of firmware, you can find:
Code: Select all
#define X_MAX_POS 210
#define X_MIN_POS 0
#define Y_MAX_POS 210
#define Y_MIN_POS 0
#define Z_MAX_POS 180
#define Z_MIN_POS 0
Check if the value of first line is 100.
XYZM
Post by XYZM »
Im pretty sure its not within in the software because on the manual control screen at the point it stops it says X=200 Y=200 Z=180
Or am I just assuming the X axis needs to go all the way to the end? and it does not have to?
zhangxueyou
Yes, you are right.
How about controlling the x motor with LCD screen?
Before moving the motor, let all the axes auto home.
XYZM
Post by XYZM »
oh. I did not include the LCD in my package.
Could it be the belts or the voltages?
My voltages are at .055
But anything higher just makes it noisy with no movement
zhangxueyou
What is the type of motor driver? Could you please take a photo, and let me check if it is plugged correctly.
XYZM
Post by XYZM »
DRV8825
The motor drivers were already installed so I doubt that is the issue.
Here is a picture
zhangxueyou
The driver are plugged corretly.
Please let me check the status of switches under x driver. It should be 1/16.
microstep of 8825.png (81.82 KiB) Viewed 10761 times
XYZM
Post by XYZM »
All the DRV drivers are on high, because this is what the build instruction said I followed it for the C model because it included info for the GT2560, but maybe it was A4988 driver..
So all of the drivers should be at 1/16?
and When would I need to use 1/32? :idea:
zhangxueyou
All should be 1/16.
