No LCD when turning on printer
x306xcptnkirk
Post by x306xcptnkirk »
I get no lcd when turning on my printer. It only turns on when I connect it to a computer. Why is this?
zhangxueyou
Re: No LCD when turning on printer
Post by zhangxueyou »
What is your printer type? What is the mainboard type?
How about swapping the connection of 2 cables behind LCD screen?
x306xcptnkirk
Sorry about that Gt2560, pro-c model, I put new printer drivers in the board. It successfully auto zeroed and I was preheating the bed to check it, turned off the printer afterwards and it would not turn back on unless I plugged it into computer. It previously turned on and was controlled by the lcd.
zhangxueyou
Is the "printer driver" you call stepper driver? If it is, is it as same as the older one?
x306xcptnkirk
Nope I put a brand new set of drivers in.
zhangxueyou
I still don't understand. Is it Marlin firmware?
x306xcptnkirk
Sorry about that. Yes brand new stepper drivers. I have not played around with the firmware at all.
x306xcptnkirk
Sorry yes they are bew stepper drivers drv8825
zhangxueyou
How did you plug the stepper driver?
x306xcptnkirk
The correct way.
