Y- Axis Failing
jfsgi
Y- Axis Failing
Post by jfsgi »
I am having issues with my Y-Axis while homing it moves forward in increments rather than to the back until it reaches the home
zhangxueyou
Re: Y- Axis Failing
Post by zhangxueyou »
Did you connect the endstops correctly? They should be connected to X-MIN,Y-MIN,Z-MIN.
If y goes in the wrong direction only when homing, you can change a parameter in "configuration.h" of firmware. If you don't know how to change it, I can send you a correct firmware.
jfsgi
Re: Y- Axis Failing
Post by jfsgi »
Please send correct firmware
zhangxueyou
Re: Y- Axis Failing
Please check your email.
jfsgi
Re: Y- Axis Failing
Post by jfsgi »
How do I use that file?
I am also having additional problems with the second extruder not working
Please advise
zhangxueyou
Re: Y- Axis Failing
You can refer to this page to upload the firmware:
http://www.geeetech.com/forum/viewtopic ... 206#p24206
You can refer to this page to set your printer in Repetier:
http://www.geeetech.com/forum/viewtopic ... 18&t=16429
jfsgi
Re: Y- Axis Failing
Post by jfsgi »
The software provided do not have the extruder tab along the top as the demo suggests
Please advise
zhangxueyou
Re: Y- Axis Failing
What software are you using?
jfsgi
Re: Y- Axis Failing
Post by jfsgi »
I get this error while trying to upload your file,
temperature.cpp: In function 'void manage_heater()':
temperature.cpp:675: error: unable to find a register to spill in class 'POINTER_REGS'
temperature.cpp:675: error: this is the insn:
(insn 98 97 100 4 (set (reg/v:SF 103 [ pid_input ])
(mem:SF (post_inc:HI (reg:HI 146 [ ivtmp.209 ])) [4 MEM[base: _110, offset: 0B]+0 S4 A8])) temperature.cpp:459 99 {*movsf}
(expr_list:REG_INC (reg:HI 146 [ ivtmp.209 ])
(nil)))
temperature.cpp:675: confused by earlier errors, bailing out
Please advise
zhangxueyou
Re: Y- Axis Failing
How did you upload the firmware?
