Error Max Temp Bed
lalink
Error Max Temp Bed
Post by lalink »
I recently bought a Geeetech prusa i3 and just finished putting it together and installing Repetier Host. I followed instructions on how to set up the software with the machine but I encountered the error message "Printer stopped due to errors. Fix the error and use M999 to restart." The LCD displays "ERR MAXTEMP BED." I have read through some posts with the same problems and checked for short circuitry within the board but can't seem to find any problems. Here's a picture of the circuit board if anyone can help.
zhangxueyou
Re: Error Max Temp Bed
Post by zhangxueyou »
I notice that you connected the endstops wrong, the wires should be connected to "SIG" and "GND".
What is the LCD displaying after you swap the connection of 2 thermistors, namely, connect hot bed thermistor to "E-THERM" and connect extruder thermistor to "B-THERM"?
lalink
Post by lalink »
The display now reads "Err: MAXTEMP" and Repetier-Host gave an error message as follows:
"Error: 0
Extruder switched off. MAXTEMP triggered!
Error: Printer stopped due to errors. Fix the error and use M999 to restart."
zhangxueyou
Please check if somewhere of hot bed thermistor is short circuit.
If you have a multimeter, please test the resistance of thermistor, it should be around 100k ohm in room temperature.
lalink
Post by lalink »
Sorry I am a noobie, but is the thermistor the wires under the tape on the heat bed?
zhangxueyou
Yes, that's it.
lalink
Post by lalink »
I've used a DMM to measure the resistance of what I believe is the thermistor, but I get no readings on the DMM.
zhangxueyou
Did you unplug the wires from mainboard to measure it?
What reading do you get when you measure another thermistor?
lalink
Post by lalink »
I get a reading of 87.8 kilo-ohms from the bed thermistor when I turn on the machine without running the program. But now the error on the display reads "Err: MINTEMP"
zhangxueyou
lalink wrote:I get a reading of 87.8 kilo-ohms from the bed thermistor when I turn on the machine without running the program. But now the error on the display reads "Err: MINTEMP"
The bed thermistor looks fine, when the temperature is 25 degrees, it's about 100k ohm.
Please check if extruder thermistor is well connected. When LCD displays "err: mintemp", extruder thermistor is not well connected to mianboard, or it's open cricuit somewhere.
