Print will not start
Darshon
Post by Darshon »
I got my a4988 today and all axis are working. I can control them. The heat bed is not getting up to temp. and I have tried printing with both heat bed on and off. the extruder gets up to temp, I can control it in repetier, but it will not print. When I click to start print it just says print is finished.
Sherry
Re: Print will not start
Post by Sherry »
what's type of the printer and control board.Maybe the g-code goes wrong,i will send you the right g-code.
Darshon
Post by Darshon »
I have been able to print now, I figured it out, but the second extruder heats and will not extrude. I was sent an email from Melody at geeetech and told to flash the firmware. I am now trying to figure out how to do that. Supposedly that might fix the second extruder?
Sherry
Post by Sherry »
Darshon wrote:I have been able to print now, I figured it out, but the second extruder heats and will not extrude. I was sent an email from Melody at geeetech and told to flash the firmware. I am now trying to figure out how to do that. Supposedly that might fix the second extruder?
this is guidance for how to set up for dual extruder.
how to set up for dual extruder.zip
(2.86 MiB) Downloaded 408 times
