Help with Prusa i3 C Dual Extruders
kazmut
Post by kazmut »
Hi! I have had my 3d printer now for three weeks, It has been goo and I was able to do everything that I wanted. But today, when I tried to print, I noticed that the filament was not feeding through, thats when I notice that the motors were not turning. Thinking it might be an issue of blockage or jam, I tried to clean the nozzle, thats wen I noticed that the i couldn't control the printer anymore. Althought I can manipulate and command the printer, nothing happens. I can see the target temperature being reeflected pm thje LCD screen but the actual temperature doesn't go up at all. I thought it might be a firmware issue so I tried to flash using the firmware you guys sent me over email. I am new to programming so there's a lot that I don't understand. I keep getting errors when i try to upload the firmware.
"/var/folders/wg/mk33xbz14hzcz23gk0vgkm2h0000gn/T/build743239427869338636.tmp/temperature.cpp: In function 'void manage_heater()':
/var/folders/wg/mk33xbz14hzcz23gk0vgkm2h0000gn/T/build743239427869338636.tmp/temperature.cpp:675:1: error: unable to find a register to spill in class 'POINTER_REGS'
/var/folders/wg/mk33xbz14hzcz23gk0vgkm2h0000gn/T/build743239427869338636.tmp/temperature.cpp:675:1: error: this is the insn:
(insn 98 97 100 4 (set (reg/v:SF 103 [ pid_input ])
(mem:SF (post_inc:HI (reg:HI 146 [ ivtmp.209 ])) [4 MEM[base: _110, offset: 0B]+0 S4 A8])) /var/folders/wg/mk33xbz14hzcz23gk0vgkm2h0000gn/T/build743239427869338636.tmp/temperature.cpp:459 99 {*movsf}
(expr_list:REG_INC (reg:HI 146 [ ivtmp.209 ])
(nil)))
/var/folders/wg/mk33xbz14hzcz23gk0vgkm2h0000gn/T/build743239427869338636.tmp/temperature.cpp:675: confused by earlier errors, bailing out
Error compiling."
How do I correct this??? Do you think I still need to update the firmware? X,Y,Z and heaters don't work at all.. Thank you
kazmut
Re: Help with Prusa i3 C Dual Extruders
Post by kazmut »
this has been corrected by the new firmware released. thank you.
