Hi all expected.
I just finished install the g2 smooth rods and form the G2 frame , it seem the rods couldnt be tightened to form the steady frame !? Assume if powerup the Delta arm movement will cause the frame to move a lot and may cause accuracy issue. Is this normal ? Please help.
Shacky structure (smooth rods)
fotomickey
Re: Shacky structure (smooth rods)
hi,if you assemble the delta according to the building instruction,the printer will work perfectly since it has been tested by our experienced engineer.i will send you the latest building instructions which has more clear information.please check your mailbox.fotomickey wrote:Hi all expected.
