Repetier + Slic3r update
gidim
Post by gidim »
Hi.
I tried to update my original Geeetech repetier software folder to the latest on thats on the web:
http://www.repetier.com/download/repeti ... ows-1-0-6/
im using win 7, 32 bit.
Im getting the following error when I try to run it.
Description:
Stopped working
Problem signature:
Problem Event Name: APPCRASH
Application Name: RepetierHost.exe
Application Version: 1.0.0.0
Application Timestamp: 548b0e64
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7601.18847
Fault Module Timestamp: 554d7b00
Exception Code: e0434f4d
Exception Offset: 0000812f
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Any suggestions on whats wrong and how to fix it?
if not, please advise how I can transfer all my slic3r settings and printer settings to work with the new ver.
Thanks.
Sherry
Re: Repetier + Slic3r update
Post by Sherry »
please try to upgraded ".net framwork 4.0".
gidim
Post by gidim »
Hi.
I have ".net framwork 4.0".
If I install the software in a clean directory and not under the GEEETech directory it works fine. Its only if I overwrite the original installation directory that its not working.
Please advise.
