Delta Rostock mini G2s ROD bearing frozen
DigitalJax
2 of my rods have bearing that are too tight. after having new carriages printed locally I reassembled the printer and tried to set up the auto leveling. the new carriages have cracked again and I have found that the bearing in two of my rods are so tight that the are over stressing the parts. How can I bet replacement or purchase new rods??
Re: Delta Rostock mini G2s ROD bearing frozen
hi,please contact the salesman.
DigitalJax
What salesman? This was a gift. I thought this would be a manufactures issue.
hi,maybe it is not matter with manufactures issue.you can contact geeetech customer service to help you solve the problem.DigitalJax wrote:What salesman? This was a gift. I thought this would be a manufactures issue.
in additon ,as you known, this is a diy kit,if it is mounted unproperly,it will be easily damaged when moving.and some customer have encounter with same problem as yours.so please check the assembly.look at this picture .
hope these will help you.
- QQ图片20150729155023.png (245.9 KiB) Viewed 8320 times
