Inconsistent Movements
Coltan89
Post by Coltan89 »
To all Delta users,
I have a new G2S and still in the initial setup but I am having issues with the manual controls. I have noticed that movements in certain directions such as left on X-axis,up on Y-axis, and down on Z-axis when doing steps of ten are moving steps of ten. But as I move the machine to the right on X-axis, down on Y-axis, and up on Z-axis that it is only moving one step when I give it a command of ten steps. This is quite a big issues as I can not calibrate the machine. I have been searching the code to find some errors but with no luck. If anyone else has had this issue and have a resolution for such a problem, please let me know.
Thanks.
rickr
Re: Inconsistent Movements
Post by rickr »
Sorry, I don't have an answer for you, but I have the same problem on the Delta Rostock Mini G2.
How about 50 steps? Are they conduct like this again?
Coltan89
Post by Coltan89 »
The movements are not constant. Sometimes the 50 it will move 50, other times it does not move 60.
