Mini G2S Extruders not extruding
So I think I just about have everything dialed in on my G2S except the extruders don't seem to extrude.  I have the 0.35mm nozzles with my kit.  I do have trouble feeding the 1.75mm filament into the lower feeder tube that goes down to the extractor.  I usually have to move the fan out of the way in order to make the filament feed.  Does anyone have any tips on how to get the G2S extruders loaded easily?  I can't say for certain if this is related to the failure to extrude.
Once I get the filament loaded, I am able to advance it all the way up to the hotend itself. When I heat the hotend to 200C, it heats up and if I let it sit there, I will see a slow ooze of filament coming out. That tells me the hotends themselves are not jammed. That being said, I can't make the motors force extrude any filament. With my other printer, if I manually extrude, a fine string of filament comes out. The motors either aren't strong enough to force it through the extruder or there is something set incorrectly. There are no directions on the what each screw adjuster does on each extruder. I would definitely like some tips here to see if I can get the extruders going. I am open to any number of suggestions here. I think this is the only thing left for me to do to be able to start printing.
Re: Mini G2S Extruders not extruding
the motor seems lack of power, how about adjust the driver voltage of the extruder motor?
I checked the voltage last night and they were about .7v.  I adjusted them up to 1.0v and it did not make a difference.  I was told via a previous email to targe 1.0v with the extruder motors.
When you manually control the extruder motor,did it actually turning?
It tries but nothing happens.  I can not force material through manually either by holding the extruder 'clutch' down and pushing on the material.  I believe the hotends are bad even though they heat up.
How about feed the filament by hand without the tube plugged in? or even without the filament, does the motor turning?
I have tried that too and am unable to force material through either hotend.  It just slowly oozes out a little melted material but it never extrudes a filament.  I am pretty sure I need replacement hotends.
Have you checked the temperature ? PLA 210 and ABS 230. And you haven't told us the motor works or not.
Yeah.  I have tried several temperatures from 190-215 for PLA and none of them worked.  They are sending me new thermistors and nozzles finally.  I hope this takes care of the issue and gets this printer going.
Well here is where I am now.lol got it all working can use gcodes but g29 code crashes print head not able to go father . if I try to print seems it goes through g29 code & crashes print head. Set z min to true.. what else can I do? Just a little bit away from getting this working please help asap. Looked on forum already.. still looking.
But when hot end is working set temp 190 – 225 seems it melted??? No pla extruded not working…. Extruder motor is working in correct direction . is this going to happen to second hot end also? Do I need new hot ends? If so I will need two.
