error code and dont star working I3 pro 3d printer
Lbciauen1
Post by Lbciauen1 »
Mi repetier connect correctly, but i recive the next code:
20:00:43.843 : OpenGL version:2.1.0 - Build 8.15.10.2182
20:00:43.843 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_EXT_texture_swizzle GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_EXT_framebuffer_blit GL_ARB_vertex_array_object
20:00:43.843 : OpenGL renderer:Intel(R) HD Graphics
20:00:43.843 : Using fast VBOs for rendering is possible
20:01:10.932 : The port 'COM33' does not exist.
20:02:11.618 : start
20:02:11.618 : echo: External Reset
20:02:11.618 : Marlin 1.0.0
20:02:11.618 : echo: Last Updated: Apr 14 2015 15:13:30 | Author: (Eddie, Sanguino 1.3)
20:02:11.618 : Compiled: Apr 14 2015
20:02:11.618 : echo: Free Memory: 4057 PlannerBufferBytes: 1232
20:02:11.618 : echo:Hardcoded Default Settings Loaded
20:02:11.618 : echo:Steps per unit:
20:02:11.618 : echo: M92 X78.74 Y78.74 Z2560.00 E95.00
20:02:11.618 : echo:Maximum feedrates (mm/s):
20:02:11.618 : echo: M203 X400.00 Y400.00 Z2.00 E45.00
20:02:11.618 : echo:Maximum Acceleration (mm/s2):
20:02:11.618 : echo: M201 X5000 Y5000 Z50 E5000
20:02:11.618 : echo:Acceleration: S=acceleration, T=retract acceleration
20:02:11.618 : echo: M204 S1000.00 T2000.00
20:02:11.618 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
20:02:11.618 : echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
20:02:11.618 : echo:Home offset (mm):
20:02:11.618 : echo: M206 X0.00 Y0.00 Z0.00
20:02:11.618 : echo:PID settings:
20:02:11.618 : echo: M301 P19.86 I1.00 D98.93
20:02:12.132 : N1 M110 *2
20:02:12.132 : N2 M115 *4
20:02:12.132 : N3 M111 S6 *68
20:02:12.632 : N4 M105 *3
20:02:12.647 : N5 M111 S6 *66
20:02:12.663 : N6 M80 *61
20:02:12.663 : N7 M80 *60
20:02:15.003 : echo:SD init fail
20:02:15.003 : echo:Unknown command: ""
20:02:15.018 : Error:Printer halted. kill() called!
20:02:15.065 : N1 M110 *2
Re: error code and dont star working I3 pro 3d printer
"20:01:10.932 : The port 'COM33' does not exist."
It says the com port does not exit, try to re-install the USB driver.
Lbciauen1
Post by Lbciauen1 »
I already connect again and the comm por now y correct, but y still receiving this:
09:26:40.938 : OpenGL version:2.1.0 - Build 8.15.10.2182
09:26:40.939 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_EXT_texture_swizzle GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_EXT_framebuffer_blit GL_ARB_vertex_array_object
09:26:40.939 : OpenGL renderer:Intel(R) HD Graphics
09:26:40.939 : Using fast VBOs for rendering is possible
09:28:59.655 : start
09:28:59.655 : echo: External Reset
09:28:59.655 : Marlin 1.0.0
09:28:59.655 : echo: Last Updated: Apr 14 2015 15:13:30 | Author: (Eddie, Sanguino 1.3)
09:28:59.655 : Compiled: Apr 14 2015
09:28:59.655 : echo: Free Memory: 4057 PlannerBufferBytes: 1232
09:28:59.655 : echo:Hardcoded Default Settings Loaded
09:28:59.655 : echo:Steps per unit:
09:28:59.655 : echo: M92 X78.74 Y78.74 Z2560.00 E95.00
09:28:59.655 : echo:Maximum feedrates (mm/s):
09:28:59.655 : echo: M203 X400.00 Y400.00 Z2.00 E45.00
09:28:59.655 : echo:Maximum Acceleration (mm/s2):
09:28:59.655 : echo: M201 X5000 Y5000 Z50 E5000
09:28:59.655 : echo:Acceleration: S=acceleration, T=retract acceleration
09:28:59.655 : echo: M204 S1000.00 T2000.00
09:28:59.655 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Zjerk (mm/s), E=maximum E jerk (mm/s)
09:28:59.655 : echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
09:28:59.655 : echo:Home offset (mm):
09:28:59.655 : echo: M206 X0.00 Y0.00 Z0.00
09:28:59.655 : echo:PID settings:
09:28:59.655 : echo: M301 P19.86 I1.00 D98.93
09:29:02.458 : N1 M110 *2
09:29:02.459 : N2 M115 *4
09:29:02.459 : N3 M111 S6 *68
09:29:03.033 : echo:SD init fail
09:29:03.067 : Error:Printer halted. kill() called!
And I have de message 10 commands waiting
How about re-install the firmware? I'll attach it to you.
PI3B-Sanguino.rar
(229.88 KiB) Downloaded 505 times
Lbciauen1
Post by Lbciauen1 »
I try to install teh firware that you sent, but i cant, how can y do it ?
