Hi I just got a Geeetech Prusa I3 X and everything works fine, except the Extruder motor.
I know the motor works, because when I switch the cable with another moter it is turning...
I see that some people have similar problems, and they change the "firmware"...how do I do that?
Hoping someone knows something...
Extruder moter dont turn....
Re: Extruder moter dont turn....
you can download the latest firmware to fix it, here is the link:
http://www.geeetech.com/forum/viewtopic ... 10&t=17046
and you can refer to the link here to install the firmware:
http://www.geeetech.com/forum/viewtopic ... 20&t=16433
Also if you run into those common problems like wrong direction of motors, hotbed not heating up or something else, you can check it here first:
http://www.geeetech.com/forum/viewforum.php?f=13
