Hi Guys,
I tryed many many firmware for my prusa i3x, but the Extruder Stepper doesn't work.
I used the fw I3_Pro_x firmware ( http://www.geeetech.com/forum/viewtopic ... 10&t=17046 ) and other many fw but null.
I tried to change the cable, the A4988 driver, but doesn't work.
I tested the stepper and work very well if I plug the extruder cable into the X or Y from the motherboard, using the LCD I can see that working.
Please see my video.
https://youtu.be/ncdnXltPSKo
I tried to change differents parameters into the configuration.h but null.
Please help me.
Thanks.
Riko
						[HELP] Extruder Stepper doesn't work!!!!
Re: [HELP] Extruder Stepper doesn't work!!!!
Hello you need to heat up your hotend, the extruder will not move until the temperature reaches 170 degrees~~
check this link here:
http://www.geeetech.com/forum/viewtopic ... 13&t=17097
