firmware for Geeetech Prusa I3 M201
rogue88
Post by rogue88 »
Hello, friends.
I need a firmware for Geeetech Prusa I3 M201, GTM32.
Thank You
P.P. kto@progress-sz.com
Re: firmware for Geeetech Prusa I3 M201
rogue88
Post by rogue88 »
Thank You, the firmware is updatet.
But!
I have installed Repetier Host 0.9 and 1.6 and a couple of drivers. The printer can not be seen.
Other problem that I have is with positioning x and y.
Please help
have you tried the FTDI driver? is the same as the GT2560.
you can download it here:
http://www.geeetech.com/wiki/index.php/ ... he_drivers
rogue88
Post by rogue88 »
Yes, I am with this driver. When I connect usb cable of the printer, It connects to COM6.
If I try in Repetier Host another Com, It gives a mistake.
When I connect Com6, it says nothing, but I can not move , nothing. It looks like as not connected.
What can I do?
the baud rate is 115200 and the receive cache size is 63, did you set it correct?
rogue88
Post by rogue88 »
Yes, It shows only, that 6-7-14 commands waiting.
This is down in the middle.
Any advice?
does your LCD working? how about other baud rate?
rogue88
Post by rogue88 »
Yes, LCD works. I have tried all the rate untill 230400. Nothing happens.
rogue88
Post by rogue88 »
So I have succeed to start the printer with Repetier Host 1.6.
But I still have a problem with Xo and Yo.
The second problem ist with the extruder heater. He wouldn't start? Why?
