Extruder Carraige Lower Than Extruder Nozzles
GeoGod
Post by GeoGod »
I have a Prusa i3 Pro C with dual extruders. Is it normal for the extruder nozzles to be higher than the metal mounting bracket? They are at least 3mm higher than the bottom of the bracket. How much of a PITA is it to lower them so I can get them closer to the bed?
Extruder Nozzle (Small).JPG (62.14 KiB) Viewed 7933 times
Re: Extruder Carraige Lower Than Extruder Nozzles
no standard for that, just make sure the nozzle is lower than the bracket or you want be able to print.
GeoGod
Post by GeoGod »
Mark, did you have to adjust your nozzles? Maybe mine was set up for a different mounting bracket. How much work is it to lower them?
it will take you sometime to make them parallel, unscrew the upper nuts to lower the hotend, but do not touch the nut on the block, it might leaking.
Ruffturn
Post by Ruffturn »
Thank you Mark. I have the same issue and I'm happy to hear that it has already been discussed. It doesn't look like fun, but at least I know what I need to do. Thanks again. :)
