Hello!
10 mounths ago I bought a Geeetech prusa mendel i3 (acrylic 8mm frame). Almoast 2 weeks ago from now my controllboard started to smell bad. I did notice that the connector for the hotbead was totaly burned out.
I did buy a new GT2560 board and a new hotbead just to be sure but I cant get the new board to work. After uploading it with the firmware called I3 pro&proB
I3 pro&proB(GT2560)
Marlin-PI3_Pro_B.zip
Marlin-PI3_pro_B
(299.21 KiB) Downloaded 383 times
It still dosen't work. The LCD is totaly dead and the X-axis sounds like gravel in a foodblender when you try to move it.
I need to get my printer going now, there for I offer a reward for the one that can guide me untill it works. I have no problem connecting to you with skype, webcam and split screens with full contol. Just help me.
Best regards,
DarkHeavenNetwork
Installing new GT2560 board
Re: Installing new GT2560 board
seems need to adjust the driver voltage of the X axis, and the LCD, did you plug the LCD cable and SD card cable in the worng place?
Hello!Mark wrote:seems need to adjust the driver voltage of the X axis, and the LCD, did you plug the LCD cable and SD card cable in the worng place?
I have tried mounting the plugs both ways. Non of them works
The thing about adjusting the voltage for the stepper motor. It worked just fine before changing the card, do you think it still needs to be adjusted then?
could you get 5V and 12V on the board? the LED lights, are they all come on?
check this link :
http://www.geeetech.com/forum/viewtopic ... 13&t=17039
check this link :
