Will i3 Pro C Support Mk3 Al Heatbed
GeoGod
Post by GeoGod »
I would like to implement auto bed leveling using an aluminum heat bed. Will the Geeetech i3 Pro C support the power requirement of the Mk3 aluminum heat bed without any modification? I have seen lots of articles where people have stated it draws more current from the power supply than the Mk2b and there could be a risk of it damaging the control board. Many people also seem to connect it with a separate power supply with a relay.
Re: Will i3 Pro C Support Mk3 Al Heatbed
The resistance of the heatbed on I3 pro C is about 1.2-1.5ohms, and the rated power is 96W. And the hotend is 40W each.
So you need to mind those values of your MK3 heatbed. Better to use another PSU.
GeoGod
Post by GeoGod »
Okay, I have a couple of questions. 1) I am not really an electrical guy but I can follow instructions. I have spent the last day looking for a good easy to follow "how to" guide on wiring up a secondary power supply for the heated bed. All I can find are explanations such as "hook up the power supply with a relay in between" ???? and 2) Rather than have 2 power supplies, could I just get a PC power supply with dual 12v rails and run the heat bed off 1 rail and the rest of the other? The one I am looking at has 23A on 1 rail and 20A on the other.
yeah a PC power supply will do, as long as it has a 12V output and the power is enough.
