calibration i3 acrylic
marmite
Post by marmite »
hi iam having problems with my settings on my printer esteps or calibration i dont really know.
What settings do you guys use on your printers?
it should be the same on all printers right? well all geeetech i3 prusa acrylic
here is a example
Re: calibration i3 acrylic
the E steps, you can make a mark on the filament, manually extrude 50mm through the repetier host and compare it to the actual feed length to increase or decrease the steps to a proper value.
marmite
Post by marmite »
thanks mark!
how about the steps for xyz axis?
they are the same, measure the actual dimensions of the object and then calibrate X Y Z steps.
