REPETIER HOST CURA PROBLEM
hooked
Post by hooked »
I have been using Repetier Host with Slic3r. I tried using the Cura engine and have a problem that I want to fix.
When I slice the job and then print the following happens:-
1. The print head moves to the bed as if to start printing.
2. The print head does not move in X/Y direction.
3. The filament retracts about 100mm.
Occasionally I have had it print without the above condition. As I want to use Cura as my preferred slicer software, I would like to resolve this issue.
Any advice will be well received.
THANKS
Daryl
Re: REPETIER HOST CURA PROBLEM
what's your printer type? is your printer working well withthe slic3r engine?
hooked
Post by hooked »
Hi Mark,
Thanks for your reply. My printer is a G2 and works fine running Slic3r.
I have since found a resolution by Google search.
In the Start code of Cura, the command G92 E0 must be entered. Then Cura works fine.
Cheers
Daryl
