Today I woke up to check the results of printing overnight. With a horror I have found again freezed  printer (happened couple of times already randomly) with heaters on and burned plastic around nozzle.  Also I have found a bit melted board connector of the bed. Therefore I decided to study if there is any safety features which can prevent fire in the end. Turned out there is topic dedicated and cases of fire caused by faulty of 3d printers  (http://reprap.org/wiki/Safety).
However I have a questions:
Is it normal that printer gets stuck randomly?
Why do we have WATCHDOG function OFF in our default firmware for I3x?
Can we use ATX power supply connected to mainboard to organize failure power off?
Do you use fireproof insulation for heating bad?
Which other passive and active fire safety features do you use?
						Fire safety, watchdog function on gt2560
				valdemar4eg
Return to “Feedback&Suggestion”
				Jump to
 - Firmware
 - 3D Printer
 - ↳ Thunder
 - ↳ Mizar Pro
 - ↳ Mizar S
 - ↳ Mizar
 - ↳ Geeetech I3 Pro B
 - ↳ Geeetech I3 Pro W
 - ↳ Geeetech I3 Pro X
 - ↳ Geeetech I3 Aluminum
 - ↳ Geeetech I3 Aluminum Pro
 - ↳ Geeetech I3 Duplicator 5
 - ↳ Geeetech I3 Pro C
 - ↳ Geeetech I3 M201
 - ↳ Geeetech A10 Series
 - ↳ A10T
 - ↳ Geeetech A20 Series
 - ↳ Geeetech A20
 - ↳ Geeetech A20M
 - ↳ A20T
 - ↳ Geeetech A30 Series
 - ↳ A30M
 - ↳ A30 PRO
 - ↳ Geeetech E180 Mini
 - ↳ Geeetech MeCreator2
 - ↳ GiantArm D200
 - ↳ Geeetech Delta Series
 - ↳ Geeetech DP200 Series
 - 3D Printing Software
 - ↳ Software
 - ↳ Wifi Box
 - ↳ Bug report
 - ↳ Download
 - Hardware
 - ↳ 3D Printer Hardware
 - ↳ Stepper Motor
 - ↳ Control Board
 - ↳ Extruder
 - ↳ Hot bed
 - ↳ LCD Panel
 - ↳ Power Supply Unit
 - ↳ Assembly
 - ↳ Others
 - Print Quality
 - Resoures Sharing
 - Feedback&Suggestion
 - Project Talent Show
 - Other Discussion
 - ↳ Leveling Guide
 - ↳ Open Hardware
 - ↳ Mods And Hacks
 - ↳ Products FAQ
 - ↳ Tips & Tricks
 - ↳ Discuss & Help
 - ↳ Windows
 - ↳ MAC
