Replacement control board and drivers
Posted: Tue Mar 22, 2016 10:38 pm
by DennisFBailey
I am running a Prusa I3 M201 with GTM32 control card. Due to incorrectly installing a driver card into the control board there was some smoke and a whole lot of time and money wasted whilst I ordered new driver cards and control board from Geeetech. Having received the replacements, I (CAREFULLY!) reinstalled the control card and driver cards ensuring that they were the right way up but it appears I have the same problem and ... I think ... the control board has gone phut again! I did get an initial positive response and the display showed the normal screens but I was getting no response from the stepper motors and then the smoke from the control board. I have checked the install instructions again but I cannot be clear on the orientation of the driver boards - I installed the cards with the potentiometer at the top of the card ... is this right?
Is there any way of rescueing the control board and/or the driver boards or proving that they are OK? .. I am getting no display on the screen and stepper motors do not move. In the event that these are damaged, is there anywhere in the UK that I can source parts as the cost of parts and carriage via DHL is astronomical
Re: Replacement control board and drivers
Posted: Wed Mar 23, 2016 5:48 pm
by Mark
what's your card's orientation looks like? do you have a picture? and how's your PSU wirings and board wirings?
Posted: Wed Mar 23, 2016 8:24 pm
by DennisFBailey
Hi Mark,
I transferred the cables 1 by 1 from the old board to the new board so they should be in exactly the same positions. I think the new board was a Rev A (large USB plug rather than mini plub - but the board has Rev B printed by the name (see pictures)) rather than the original which was a Rev B board. Power supply has been operating successfully before the board blew up and I have not changed any settings or voltages on this so should be OK.
Posted: Thu Mar 24, 2016 5:53 pm
by James Zou
pictures.zip
(1.04 MiB) Downloaded 713 times
hi,friedn,you plug the drivers with wrong orientation,you also didn't unplug all the number 1 and number 2 jumper caps as shown in the pictures.
Posted: Thu Mar 24, 2016 5:55 pm
by James Zou
Sorry,i forget to tell you that I put the two pictures in the attachment,because the website can't support such a high pixel picture.
Posted: Thu Mar 24, 2016 7:38 pm
by DennisFBailey
Thanks James. The pictures on the build instructions were not clear. I have reorientated the drivers on the board and removed the jumpers from pins 1 and 2 but, unfortunately, I still get smoke wafting off the board when I switch on and no activity whatsoever so I assume that the board has been zapped by my initial action?
I have reordered yet another board from Geeetech!
Can you advise if the driver boards would have survived the incorrect plugging or will these need to be replaced as well?
Posted: Sun Mar 27, 2016 5:42 pm
by Mark
If the drivers are burned out, usually there will be a burning hole on the center of the driver chip, all my 4988 have such a black hole when burned out.
