Hi geeetech team, i have a problem with my g2s, after i upgraded to all metal parts i was able to print but there is problem with the extruders offset i am not able to fish no matter what settings i change in repetier or the firmware. changing the extruder offset in repetier to a very high number and the print is not effected at all as you can see in picture #1. i also changed extruder offset in firmware and the extruders just go to a higher position causing the print to be on empty space. i have read many past posts and i did not find any information for this problem. you can see in image #2 that my layers have over two mm in offset. i also looked in many places in the firmware and i can not find where i can change the position of the extudrers. can anyone tell me where i can fix this problem in the firmware because the setting in repetier do not have effect on the print. see pictures 3 and 4. thanks for the help.
video of image #2 :
https://youtu.be/3C_Ba1M7o9k
extruder offset not working; layer shifting on materails
- index.jpg (131.33 KiB) Viewed 4818 times
- index4.jpg (123.68 KiB) Viewed 4818 times
- https://youtu.be/3C_Ba1M7o9k
- index5.jpg (160.85 KiB) Viewed 4818 times
- index2.jpg (214.03 KiB) Viewed 4818 times
Re: extruder offset not working; layer shifting on materails
If you followed all the instructions in user manual,the problem still exists,it must be the mater of slicing, please set your printer as instructed in user mabual and use this sliced config file.
