Prusa I3 Pro B, did not operate
neo4th
Post by neo4th »
I have a new GEEEtech Prusa I3 pro B but it does not work.
The Powersupply has the correct Output =12,3 V, on the GT2560 Rev A Board i also have the 12V and on the Testpoint the +5V, the Extruderfan and the Boardfan are running,
on the A4988 Boards I also have the +5V. The Headbed and Extruder Led is green also the USB Led.
The LCD shows no letters, only black squares, all engines stand still and you can´t move them by hand.
In Repetier Host GEEEtech you can connect the Com Port but you can´t do anything, it shows “room temperature/0, room temperature/0”.
I startet to download a new Firmware with Arduino, but after 10 Minutes it fails with a lot of timeout and other errors: "avrdude: stk500v2_ReceiveMessage(): timeout" or
"avrdude: stk500v2_getsync(): timeout comunicating with programmer".
Sorry for the bad english
Please help, thanks
Christoph
Admin
Re: Prusa I3 Pro B, did not operate
Post by Admin »
first what is the arduino ide version you use to upload firmware, please try with 1.0.1 version.
after you upload the firmware sucessfully,if the problem still exisit for the LCD and temprature, please check the following post:
http://www.geeetech.com/forum/viewtopic ... 23&t=17040
neo4th
Post by neo4th »
Thanks for the fast answer.
I use Arduino 1.0.1 for uploading the Firmware, but again I only get:
ReceiveMessage (): timeout or
getsync(): timeout communicationg with the programmer or
command(): failed miserably to execute command 0x11
I have also tryed to unplug all kables exept USB and again nothing worked.
Christoph
Admin
Post by Admin »
seems that your board is dead.
please contact the seller for a replacement.
