i3 Y-axis drifting
frovin
i3 Y-axis drifting
Post by frovin »
I have problems with my Y-axis (the heat bed). It's drifting slightly, and mostely in the lower layers. This is what a test print looks like when printed in transparent PLA at 200/70 C. If I do a test print and return the nozzle to 0,0,0 the printer is still in calibration, so it's not the stepper loosing steps or something like that. I tried increasing and decreasing the belt tension without any change in result. My own guess is that the threaded rods on the Z-axis are not 100% straight ?
Any suggestions are welcome !
frovin
Re: i3 Y-axis drifting
Post by frovin »
The problem has been solved. I was the wheel inside belt pulley in the y-axis which did not rune totally smooth. I loosend the diagonal screw a little, and that was it.
leoval
Post by leoval »
Hi!!!
I have the same problem too!
Here is the photo showing the displacement...
photo 1.JPG (251.67 KiB) Viewed 8032 times
more close...
photo 2.JPG (212.31 KiB) Viewed 8032 times
Please, if anyone know how to calibrate or solve the problem, we appreciate the contribution!!!
I have a Geeetech Prusa I3 Pro C.
Thanks a los and have a nice day!!!
Leo
Admin
Post by Admin »
frovin wrote:The problem has been solved. I was the wheel inside belt pulley in the y-axis which did not rune totally smooth. I loosend the diagonal screw a little, and that was it.
:D good
