I need help
I did everything as described in the instruction guide. After homing the printer with G28 code and sending G29 code, my printhead will get all the probing points as it should, then it will rise 50mm high after the last probing point as expected. After that, when I enter G1 X0 Y0 code, the printhead moves immediately downwards and crashes into the bed... It shouldn't move in the Z direction when sending this code... I have also tried sending manual commands instead of G1 X0 Y0, like moving upwards in Z direction (I even tried downward Z command to make sure nothing was inverted), but any command I send will still move the printhead down and crash into the bed. The only command that will not make the printhead crash into the bed is G28, but if I do so my printer will loose all probing points coordinate and the auto-leveling becomes useless..
Any idea what the problem may be? I have looked into many forums but nobody seems to have this same issue as I have.
Any help will be very much appreciated
