Power Supply did not work
bridger
Post by bridger »
Out of the box my power supply did not work. I wired it correctly but it is not working. There is 110v supplied to it but the fan does not run, the LED does not light up, and there is nothing on the output of the device where I should be getting the 12v. Can I please get a new one?
Admin
Re: Power Supply did not work
Post by Admin »
All the power supply is stictly tested before shipping.can you please post some photos of your wiring.
bridger
Post by bridger »
This one must have slipped past your inspection. It is wired correctly. There is no voltage on the output, but there is definitely 120v on the input. I tested it with a volt meter. I know that in the picture the power cord is not plugged in but I did have it in and it was not working. I had to borrow a cord from another appliance because I was also sent the wrong cord. I needed the one to use in the US.
The wires in the middle are negative 12v wires, the black in on the back side.
bridger
Post by bridger »
I am also missing the fittings for the bottom of my two extruders (I have the m201).
I need them for the tubing to fit into so I can get the filaments to the hotend.
See, I am holding the tube in the air. There is nothing for it to attach to and all of your pictures show that there is supposed to be those fittings for the tube.
Admin
Post by Admin »
bridger wrote:Hello,
The attachment Capture.JPG is no longer available
how about another side?
check the picture.
power input.png (155.56 KiB) Viewed 12660 times
Admin
Post by Admin »
please provide your order number or you can contact the seller directly for the missing part.
bridger
Post by bridger »
This is wired correctly as well. The power supply does not work.
back of plug.JPG (28.15 KiB) Viewed 12633 times
front of plug.JPG (29.47 KiB) Viewed 12633 times
bridger
Post by bridger »
Please respond to my posts and allow my posts to be posted
Lami René
Post by Lami René »
Hello bridger,
Excuse me, I use Google Translator to translate the text of the forum in French, because I'm not bilingual. Thank you for your understanding and indulgence! This is William Kwok, a forum moderator suggests me to proceed in this manner.
I bought a 3D printer Geeetech Rostock 301 (waiting to receive it) and I am informed about it. The suite is in French to reduce inconsistencies multiple translations ...
Bonjour bridger,
Excusez-moi, j'utilise Google Translator pour traduire les textes du forum en français, car je ne suis pas bilingue. Merci pour votre compréhension et votre indulgence ! C'est William Kwok, un modérateur du forum qui me suggère de procéder de cette manière.
J'ai acheté une imprimante 3D Geeetech Rostock 301 (en attente de la recevoir) et je m'informe à son sujet. La suite est en français pour réduire les incohérences des traductions multiples...
Est-ce que votre problème est maintenant réglé ?
Si oui, comment avez-vous réglé le problème ?
Sinon, quels sont vos besoins ou attentes ?
L'ami René
One for all and all for one !
