3d printed filament guide for Geeetech MK8 extruder
rita
Post by rita »
if you are using this geeetech Mk8 extruder,
http://www.geeetech.com/assembled-mk8-e ... kdgd5b87i6
you may find it difficult to get the felament right to the barrel, with this filament guide,it will be much easier.
he tested the 2mm version with filaflex, it works perfectly!
Flexible material guide for Geeetech MK8.jpg (106.62 KiB) Viewed 6534 times
Flexible material guide for Geeetech MK8-2.jpg (54.75 KiB) Viewed 6534 times
Download the stl.file here
Flexible_material_guide_for_Geeetech_MK8.zip
(152.69 KiB) Downloaded 727 times
This is designed by @ghugues on thingivers, you can find his project here
http://www.thingiverse.com/thing:801036
