Heatbed not working G-2S
Hello! assembled printer Mini G2 Pro (single extruder)
The extruder is heated to a set temperature. The motherboard connector under the power of the extruder is switched
red diode.
If you turn on the hot bed, nothing happens. Indications temperature sensor does not grow. No indication diode.
The temperature sensor shows the room temperature
Help solve this problem. Thank you!
red diode.
Re: Heatbed not working G-2S
Hi,my friendden3000 wrote:Hello! assembled printer Mini G2 Pro (single extruder)
red diode.
Have a look at this,it'll be helpful:
Hi! the connector fuse of the heated pads were not soldered at two points. I soldered and earned printer Thanks!
alberthandsome
- Contact:
I bought Folger prusa i3 Rev B and have a problem with it.
My Heat bed will not heat up and the heat bed thermister reads Zero C which is impossible (should at least be room temp).
The resistence of the Heatbed is 1.8 Ohms and that of the thermister is 95K (both within working range).
Also, The voltage at the Ramps Blue socket where the wires to the Heat bed are connected read 0 volts. R Programming Training
| DataStage Training
| SQL Training
It seemed as thought that either the Ramps board is damaged or that the Repetier host software is either faulty or not configured properly. SAS Training
| Android Training
I installed a new Ramps board but have the exact same symptoms. SharePoint Training
Any advice would be a great help
Hi,alberthandsome wrote:I bought Folger prusa i3 Rev B and have a problem with it.
Also, The voltage at the Ramps Blue socket where the wires to the Heat bed are connected read 0 volts. R Programming Training| DataStage Training
| SQL Training
It seemed as thought that either the Ramps board is damaged or that the Repetier host software is either faulty or not configured properly. SAS Training| Android Training
I installed a new Ramps board but have the exact same symptoms. SharePoint Training![]()
I guess there has a open circuit on your heatbed thermistor.Have a double check on it.And refer the following info:
http://www.geeetech.com/forum/viewtopic ... 23&t=17030
datascienceinstitute
Check for the following errors
Fuse Damage
Electronics Damaged
Wrong Wiring
Testing Heatbed
Heat Bed Resistance
Data Science Training in Hyderabad | Data Science Course in Hyderabad
Fuse Damage
Electronics Damaged
Wrong Wiring
Testing Heatbed
Heat Bed Resistance
datasciencepune
- Contact:
Nice post and great information thank you.
Data Science Training in Pune | Data Science Course in Pune
DataAnalyticspune
I feel very grateful that I read this. It is very helpful and very informative and I really learned a lot from it.
Data Analytics Course in Pune | Data Analytics Training in Pune
Businessanalyticspune
I am impressed by the information that you have on this blog. It shows how well you understand this subject.
Business Analytics Course in Pune | Business Analytics Training in Pune
datascienceprograms
- Contact:
I finally found great post here Very interesting to read this article and very pleased to find this site. Great work!
