Latest Firmware for i3 Pro C Dual-Extruder Printer
BrendaEM
Post by BrendaEM »
What the latest firmware for:
Geeetech i3 pro C dual extruder 3D printer
I had some minor scaling issues with the stock threaded rods.
Scale Factor x, y: .9792, or 1.0208
Scale z: .9835 or factor of :1.0165
[I had some issues with it quitting and shutting off the extruder.
I found that I had worn through trough the heater wires, and I am still having issues.
As it turns out the silicone over fiberglass wire that everyone uses is not that durable.]
Re: Latest Firmware for i3 Pro C Dual-Extruder Printer
BrendaEM wrote:Hi,
Hi,my friend
Would you mind explaining your issues in details?And i would be grateful if you post a pic.
BrendaEM
Post by BrendaEM »
You can't tell me what the latest firmware version is unless I first give you the information you want?
BrendaEM wrote:You can't tell me what the latest firmware version is unless I first give you the information you want?
Nope,here it is:
http://www.geeetech.com/forum/viewtopic ... 10&t=17046
BrendaEM
Post by BrendaEM »
Thanks William Kwok.
Unlike most of the boards I post to, this site does not host photos--even small photos, so I am not likely to post a photo here.
I will compare my firmware version, though I am worried about all the little changes that have to be made before uploading install it.
