I have finished building my Geeetech I3 Pro B and my X Axis is reversed.
I have the GT2560 board. Can I fix this through the LCD or an Mxxx command or do I need a new firmware?
Thanks!
X Direction Reversed
Re: X Direction Reversed
Hi,ChinookTx wrote:I have finished building my Geeetech I3 Pro B and my X Axis is reversed.
Thanks!
You can only fix it by changing the codes in the firmware,refer to this link:
http://www.geeetech.com/forum/viewtopic ... 17&t=17037
Changing the firmware codes is not the only solution. Gently removing the wires from the connector and reversing the pole positions works as well. Standard wiring order on the motor is Blue, Space, Green, Red, Space and Black. Change this to Black, Space, Red, Green, Space and Blue.
