M201 Help! It won't turn off (the hotend that is)
mark2
Post by mark2 »
So while cleaning out my hot-end over the weekend, for some reason I had a situation where the hot-end heater wouldn't turn off (even after a full power off and on again).
I took my board out and measured the mosfet, and sure enough it was knackered (shorted between pins).
After desoldering the mosfet I swapped the it with the neighbour and checked all the resistances before putting the board back on the printer again.
Imagine my surprise when the hot-end started heating immediately again, and I still can't turn it off.
Is it likely something more serious? If so is it repairable? or do I need a new board? I followed all the steps on the following thread;
viewtopic.php?f=19&t=17039
Can't find a replacement M201 board on the Geeetech site, what are my options? Is this a common problem? it's the second issue I have had with the hot bits...
Re: M201 Help! It won't turn off (the hotend that is)
mark2 wrote:So while cleaning out my hot-end over the weekend, for some reason I had a situation where the hot-end heater wouldn't turn off (even after a full power off and on again).
Was your h-thermistor normal?
Additionally,have a try to reload the firmware plz.
mark2
Post by mark2 »
Hi, thanks for the response.
Yes, thermistor is working fine, hadn't considered flashing the firmware, so I will definitely try that.
To the other question though, is it possible to get a viable replacement board?
Will let you know how it comes out.
mark2 wrote:Hi, thanks for the response.
Have you checked all in the post?
And was the hotend fuse normal?
I'm thinking,you know,is it possible the mosfet neighbour you have changed is also bad?
fahez
Post by fahez »
Now a day’s technology prove itself again by introducing 3D printer as it has many features and components for its use. Joining all the components rushmyessay.com review will provide us guidance about it.
