I'm about to fit an E3D Lite6 to my M201 and therefore to the GTM32 board. Is it possible to set the thermistor type? The instructions on E3Ds page are for the various open firmware types out there: http://wiki.e3d-online.com/wiki/E3D-Lit ... Easy.21.29
I'd rather not replace the control board since I'd like to be able to swap back to the 2-into-1 heatblock when required.
Thank you.
M201 Set Thermistor Type
Re: M201 Set Thermistor Type
Hi,cerealkillers wrote:I'm about to fit an E3D Lite6 to my M201 and therefore to the GTM32 board. Is it possible to set the thermistor type? The instructions on E3Ds page are for the various open firmware types out there: http://wiki.e3d-online.com/wiki/E3D-Lit ... Easy.21.29
Thank you.
I'm afraid you can't make some modifications in firmware on GTM32 board...
The1Fl4sher
@ William Kwok : Are you sure you can not change the firmware.
Yes,cuz the GTM32 board is not open source...The1Fl4sher wrote:@ William Kwok : Are you sure you can not change the firmware.
