If you look at this image below, you will see the four point to test for leveling. Points 1,2 and 3 are fine. When I move the printer to position 4, the second hot end hits the plate and the first hot end it still hovering higher. I have the second hot end positioned about a mm higher in all the other positions, it only gets lower when it approaches the fourth point.
Anyone help with this?
