i3 pro C dual extruder MINTEMP error
thegreen4me
Post by thegreen4me »
I have the i3 pro C and I have a problem which has just started. All 3 thermistors were working fine until today and suddenly the thermistor for extruder 1 now only shows 0 degrees and thus, a MINTEMP error. At first I unplugged all thermistors and checked each individually with a multimeter; all 3 showed a reasonable resistance. I then deliberately plugged the thermistor from extruder 1 into the port for extruder 2 and vise versa. It still showed 0 degrees for extruder 1 and 34 degrees for extruder 2, proving that the problem was not a bad thermistor.
I read in this thread that you can short the connection to the thermistor and it should show 358 degrees: http://www.geeetech.com/forum/viewtopic ... 13&t=17030
I tested that and when shorted with a jumper it did show 358 degrees and when I removed the jumper it immediately dropped back to 0 degrees.
The fact that I individually tested the thermistors plus the fact that switching them did not switch the problem extruder suggests the problem is with the control board, not the thermistors but the test I did with the jumper suggests there is nothing wrong with the board. I am now 100% stumped by this problem. Please help.
Re: i3 pro C dual extruder MINTEMP error
thegreen4me wrote:I have the i3 pro C and I have a problem which has just started. All 3 thermistors were working fine until today and suddenly the thermistor for extruder 1 now only shows 0 degrees and thus, a MINTEMP error. At first I unplugged all thermistors and checked each individually with a multimeter; all 3 showed a reasonable resistance. I then deliberately plugged the thermistor from extruder 1 into the port for extruder 2 and vise versa. It still showed 0 degrees for extruder 1 and 34 degrees for extruder 2, proving that the problem was not a bad thermistor.
It's weird.I think we can rule out the two thermistors problem now.BTW,did you test the E1 port or E2 port?
thegreen4me
By e1 and e2 you mean extruder thermistor 1 and extruder thermistor 2 ports on the control board? I tested both. e2 is working flawlessly the only issue is with e1. I have been poking around with a multimeter for a while now and I found one more interesting thing that could be a clue. When I short either of the two working thermistor ports, I get 0.9 milliamps of current from the signal pin to the ground pin. When I do the same to the port that is not working, I get 10 milliamps. That seems excessively high for a thermistor port.
thegreen4me wrote:By e1 and e2 you mean extruder thermistor 1 and extruder thermistor 2 ports on the control board? I tested both. e2 is working flawlessly the only issue is with e1. I have been poking around with a multimeter for a while now and I found one more interesting thing that could be a clue. When I short either of the two working thermistor ports, I get 0.9 milliamps of current from the signal pin to the ground pin. When I do the same to the port that is not working, I get 10 milliamps. That seems excessively high for a thermistor port.
Ye,i mean that before.You can also test the voltage of the two thermistor ports,to see is it is the normal value,and the value is 5V around.
thegreen4me
I bought a new gt2560 control board, put it in and everything works now! I am however very disappointed in geeetech. They simply refuse to honor their warranty. I spent weeks trying to contact them about getting a replacement board. I tried contacting them by email, skype, and their site's livechat. They did not ever respond to me through any of those methods. Eventually I gave up hope of them ever answering and just spent $40 of my own money on a new board. Oh well, at least I got my printer working again and I learned not to trust this Chinese company.
