Can I use DRV8825 on GTM32
Can I use DRV8825 drivers on my M201 GTM32?
I use the GTM32_DUAL Firmware.
I saw previous thread that home function does not work. Is it still the case or not with the GTM32_DUAL firmware?
Thank you
Francois
Thank you
Francois
Re: Can I use DRV8825 on GTM32
Hi,greeffbf wrote:Can I use DRV8825 drivers on my M201 GTM32?
Thank you
Francois
I'm afraid that you can't use it temporarily,as you said,there is still some problems on home function.
Does the problem lie within the firmware or the hardware ?William Kwok wrote:Hi,greeffbf wrote:Can I use DRV8825 drivers on my M201 GTM32?
Thank you
Francois
When can we expect an answer.
The GTM32 is great board, but PLEASE give us more support.
Thank you
Francois
Hi,Francoisgreeffbf wrote:Does the problem lie within the firmware or the hardware ?William Kwok wrote:Hi,greeffbf wrote:Can I use DRV8825 drivers on my M201 GTM32?
Thank you
Francois
Thank you
Francois
Thanks for your attention.I've made a feedback to our engineer before.Wait patiently plz.
Regards
Hello greeffbf,
Excuse me, I use Google Translator to translate the text of the forum in French, because I'm not bilingual. Thank you for your understanding and indulgence! This is William Kwok, a forum moderator suggests me to proceed in this manner.
I bought a 3D printer Geeetech Rostock 301 (waiting to receive it) and I am informed about it. The suite is in French to reduce inconsistencies multiple translations ...
Bonjour greeffbf,
Excusez-moi, j'utilise Google Translator pour traduire les textes du forum en français, car je ne suis pas bilingue. Merci pour votre compréhension et votre indulgence ! C'est William Kwok, un modérateur du forum qui me suggère de procéder de cette manière.
J'ai acheté une imprimante 3D Geeetech Rostock 301 (en attente de la recevoir) et je m'informe à son sujet. La suite est en français pour réduire les incohérences des traductions multiples...
Est-ce que votre problème est maintenant réglé ?
Si oui, comment avez-vous réglé le problème ?
Sinon, quels sont vos besoins ou attentes ?
L'ami René
Bonjour greeffbf,
L'ami René
One for all and all for one !
[quote="William KwokCan I use DRV8825 drivers on my M201 GTM32?
Thank you
Francois
I'm afraid that you can't use it temporarily,as you said,there is still some problems on home function.[/quote]
Thank you
Francois
Hi,Francois
Regards[/quote]
William Kwok, do you guys want to help. Still waiting.
Thank you
Francois
Thank you
Francois
Hi,Francois
Regards[/quote]
L'ami René
I can't understand why they don't want to help.
Bonjour greeffbf,
Avec mon expérience des entreprises chinoises qui vendent directement aux individus des pays occidentaux, et des documentaires sur la vie des travailleurs chinois, je serais porté a penser que les travailleurs sont systématiquement en sous-effectif pour maximiser les profits des gros patrons de l'entreprise et de l'état. De mon point de vue, les travailleurs chinois vivent dans une époque d'esclavage des travailleurs pour le présumé bien de la nation (nous savons que c'est faux) !!! En occident les affreux puissants voudraient aussi nous transformer en esclaves, ils y travaillent fort...
Je ne dis pas que tous les travailleurs chinois sont des anges, mais pour le moment, je ne peux leur jeter la première pierre.
L'ami René
L'ami René
Bonjour René
Je pense que vous êtes 100% correct. Il est juste triste qu'ils vendent au public et que le client doit en subir les conséquences.
Passez une bonne journée
Votre ami sud-africain.
Francois
Francois
Bonjour ami sud-africain Francois,
C'est à mon tour de penser comme vous à 100% ! Il est triste que le client doive en subir les conséquences !
Mais, nous avons comme solution de ne plus acheter directement chez eux et de ne pas avoir de poids économique pour eux et de passer par un gros revendeur qui lui aurait un poids économique suffisant pour ne pas être ridiculisé par leur service après-vente et assistance technique !
Pour le moment, pour le Canada, je ne connais pas de gros importateurs, mais je suis preneur si quelqu'un en connaît ?
Une autre solution est de produire nous-mêmes très localement (dans notre maison) le plus possible nos propres pièces en plastique (PLA, ABS, etc.) pour recourir le moins souvent possible à eux. Et avec une imprimante 3D qu'ils nous vendent, c'est déjà un grand pas dans la bonne direction !
Cordialement,
L'ami René
Cordialement,
L'ami René
