Extruder invert motor direction
lezabour
Post by lezabour »
I have a problem with my prusa i3 pro C. The extruder are configurated in the wrong order.
When i use repeatier host to extrude, it retract.
When i want to retract, it extrude.
Result is i cant print.
What do i have to change in the firmware?
I supposed this is here
#define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
Do i put all in true?
Thanks for help
Re: Extruder invert motor direction
lezabour wrote:Hi,
Thanks for help
You are right,these codes are controlling the extruders' direction.
Firstly,as you know your Pro C has two extruders,you'd better figure out which extruder's direction is wrong or the two both wrong.
Then you can invert the value(E0\E1),finally upload the firmware.
lezabour
Post by lezabour »
Ok, this works better!
thanks
Podfrey
Post by Podfrey »
Out of curiosity (and because I can't find the answer online), if E0 = Extruder #1 and E1 = Extruder #2, what does E2 control??
[quote=Podfrey post_id=83499 time=1522379713 user_id=62913]
... what does E2 control??
[/quote]
Extruder #0 ?
Gleanders
Post by Gleanders »
Extruder invert motor direction, We need to check different devices which help us to solve or to complete our work too fast. I am not saying you to come and use these brill assignment review devices, I am just saying that you can easily save your time and complete your work too quick.
