GT2560 Auto Reset
GT2560 Auto Reset
Is there a way to disable the Auto Reset feature on the USB line of the GT2560? When ever I plug or unplug the USB line or start or exit the Repetier software, the Printer Control Box resets and it's annoying.
Re: GT2560 Auto Reset
Hi,how about upload the firmware again?MotoBarsteward wrote:Is there a way to disable the Auto Reset feature on the USB line of the GT2560? When ever I plug or unplug the USB line or start or exit the Repetier software, the Printer Control Box resets and it's annoying.
I have done this multiple times as I have changed other settings in the firmware. For the standard Arduino boards, you can do things that are described here:-
http://playground.arduino.cc/Main/Disab ... Connection
But, on your board, there is no header. Can you give me an idea which two points on your board that I can use please?
The GT2560 is a bit different i think.I couldn't find your two point.
1.Did your board work fine when you keep the USB plugging?
2.Check if there are some components related to USB circuit appearing overheating when you plug USB cable.
3.How about changing another USB cable or a port?
