Heating element is causing the 10A fuse to blow
jaap
Post by jaap »
Hi, I have a Geeetech prusa i3 x which I recently finished putting together, but when I set the extruder to be heated, the hot end gets really hot, it starts smoking and causes the 10A fuse to blow, Please help, I haven't been able to even do my first print :(
Re: Heating element is causing the 10A fuse to blow
jaap wrote:Hi, I have a Geeetech prusa i3 x which I recently finished putting together, but when I set the extruder to be heated, the hot end gets really hot, it starts smoking and causes the 10A fuse to blow, Please help, I haven't been able to even do my first print :(
You'd better change a 10A fuse first,do you have a spare one?
jaap
Post by jaap »
I have replaced the 10A fuse with a working one and tried it again, but it blew it again. I have an image on how red the wires for the heating element get before it blows, I have also followed this http://www.geeetech.com/forum/viewtopic ... 19&t=17039 and the LED for the heating element turns on which means the MOSFET is good.
The following image is before I start the heating of the extruder
Before heating
Before heating
extruder (1).jpg (323.58 KiB) Viewed 11127 times
The following image is how hot it gets in a few seconds before the fuse blows
hot before it blows the fuse
extruder-3 (1).jpg (408.46 KiB) Viewed 11127 times
ggg666
Post by ggg666 »
The attachment extruder (1).jpg is no longer available
The attachment extruder-3 (1).jpg is no longer available
OK,sounds like the mosfet is good,have you measured the resistance of the heater,i guess the value is abnormal and has a overhigh power.
jaap
Post by jaap »
I measured it, and got 2.1 ohms, the way I measured it was I took the two wires of the heating element and made sure they were only connected to the probes of the multimeter and nothing else. I am kind of confused on what it means by testing when shorted it should be less than 2 ohms and when open circuit it is infinite? How exactly do I test that?
jaap wrote:I measured it, and got 2.1 ohms, the way I measured it was I took the two wires of the heating element and made sure they were only connected to the probes of the multimeter and nothing else. I am kind of confused on what it means by testing when shorted it should be less than 2 ohms and when open circuit it is infinite? How exactly do I test that?
I'm afraid you have to change a heater now...
jaap
Post by jaap »
How could I contact costumer service to get it replaced, since it came faulty from factory? I also have a two year warranty on the printer but don't know how the process is to getting it replaced.
Where did you buy your printer?
If you bought it from our site directly,you can contact our sales(sales@geeetech.com) to ask for the replacement,providing your order number.
If not,i'm afraid you've to contact the seller first.
